Soldier2431's avatar
Soldier2431
Weak Wi-Fi signal / Red Light
Please help. I have had my hub three for a number of years and it’s never had any other light than a red light a boat range extenders All to no avail. The signal keeps dropping out. I’ve turned it off unplugged it. I’ve done everything but thrown it through the window. I have to say that I’m thinking of going from Virgin to someone else. I also pay £58 a month so I have to use my 5G signal because the Virgin Media hub three ain’t working, please help I would love an engineer to come round.
  • jbrennand's avatar
    Red light is not indicative of any performance issues - just overheating.  So is the Hub getting hot?  If not then you issues lay elsewhere and the clues will be in the connection data - so can you do this....
    ____________________
    Firstly... Can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
    THEN:   Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
  • Zach_R's avatar
    Zach_R
    Hi Soldier2431,
    I'm sorry to hear that you're having some trouble with your Hub 3 displaying a constant solid red light. If you haven't done so already, please follow the steps below.
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If you've followed the above steps and the issue remains, please respond to the private message that I'll be sending to you shortly and we'll proceed from there with this.
    • Soldier2431's avatar
      Soldier2431
      Hi Zack
      I have unplugged, switched off and even pressed the tiny reset button on previous occasions. Yes it works fine for a few hours then poor WiFi signal. Hub is upstairs and I thought it was the location so bought a WiFi extender,still a problem. Please help.
