Chillers123's avatar
Chillers123
Virgin wifi booster sparked and not working
I can’t see how to order a new one. The old one sparked in the socket randomly now no lights come on and reset button doesn’t do anything. It is the main unit so now my son can’t use his computer as his booster obviously isn’t working and he needs it for school work. No where can I see how to get a new booster!
  • Boosters are no longer being supplied as they are a fire hazard !
    See this post for info first...
    _____________________
    To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value fire hazard, “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
    You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - if you are - it is clearly stated on the webpage.
    You can also text VM on 0753 305 1809 include account name/number and what the issue is, there is also a “Chat” option on their website - but note that replies usually take longer. Or you can speak to the team on WhatsApp by logging into your online account via a mobile handset and there will be a link to speak to VM by Whats App (the number is 0780 3089 684 ) - you can use the same number for their other social media platforms too (TwitX/Fbook. etc) - so try them all
    If not free to you… you will be charged £8/month for up to 3 pods. It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
    If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point(s), (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3).
    £40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
  • jbrennand's avatar
    • Chillers123's avatar
      Chillers123
      Thank you. I didn’t know they were a fire hazard! I’m glad I was in the room when it happened then!
      • Martin_N's avatar
        Martin_N
        Hi Chillers123,
        Thank you for your post. We're sorry to hear about your WiFi booster.
        We can certainly take a look into this for you and help get this resolved.
        I will private message you now.
        ^Martin
