almark's avatar
almark
Trying to order additional wifi pod
It took me five months to finally get my first wifi pod. Countless emails, telephone calls, formal letter of complaint and then suddenly out of the a wifi pod arrived. No explanation, no apology. In fairness it fixed the problem I was having it that room. But I needed another one for a different room. I used the vm connect app but contrary to what it says on the website, I couldn't order one after getting a poor test result. Another help page offering to help is 404.  It is like getting blood out of a stone. I am getting the runaround again, with orders promised but not delivered. I am more than happy to give all details by pm. I am the account holder, on 1GIG. Wifi max, with one wifi pod, but I need another and do not want to engage in 100s of telephone calls over five months to get this sorted.
  • Thanks for your time via PM almark
    As discussed your Pod is en route ๐Ÿ™‚
    Once received follow the instructions on this page๐Ÿ‘‰ here to get it set up.
    We're here if you need anything else.
  • Ayisha_B's avatar
    Ayisha_B
    Hi almark ๐Ÿ‘‹
    A warm welcome back to our Community Forums and thanks for your post.
    I am so sorry for the poor experience when trying to order your WiFi Pods.
    I would love to assist you further so will pop you a PM ๐Ÿ“ฉ now and we can go from there.
    Speak soon!
  • Ayisha_B's avatar
    Ayisha_B
    • Rich2750's avatar
      Rich2750
      Hi, I am having the same issues. I need to order additional wi-fi pods but website and links do not work. The 'contact us' button does nothing.
      I have one pod but getting poor WiFi signal across the house and hope two additional pods will rectify the low speeds.
      Could you contact me too to help me out? Many thanks
      • Carley_S's avatar
        Carley_S
        Hi Rich2750
        Welcome to the community forums
        Sorry to hear that you've been unable to order a second pod. We can see on the systems at our side that you've since been in touch and have a resolution sorted. Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the community forums if needed :).
  • Hi, I have recently been through the same process as above.
    I had 1 gig broadband installed last week. The Virgin connect app says I have a black spot but when trying to order a wifipod you just go round in circles. Have tried contacting Virgin but its impossible, managed to get on whatsapp with someone but they never responded. Can you help please.
    Jason
    • Carley_S's avatar
      Carley_S
      Hi tassiej
      Sorry to hear you're having issues with running the speed test to ordering WiFi pods.
      Are you able to run a speed test on the Sam Knows instead here to see what speeds you're getting in the areas of the home where the signal is poor. You'll need to be connected to the home Virgin Media network without a VPN enabled to perform the tests,
      Post your results here and we can assist further for you if needed.
      • tassiej's avatar
        tassiej
        Hi Carley,
        Thanks for responding.
        Results attached.
        Jason
  • Hi,
    I am having the same issues as the OP. I have 1GIG and 1 pod (my account says 2 but 1 was returned) but need another. I have done the test on the VM connect app and followed all the instructions through to ordering and just get an error message, tried this twice. Can some one help me get another pod order please?
    • John_GS's avatar
      John_GS
      Hi TooManyShoes
      We can see you've already placed the order since posting :)
      There are a few requirements for the Pods to work with our Hubs:
      โ€ข    The Hub must be in 'Router Mode' and not have been changed to 'Modem Mode'.
      โ€ข    Channel Optimisation must be left on.
      โ€ข    The SSIDs must be the same and broadcast enabled.
      โ€ข    The SSID must be password protected.
      โ€ข    The Passphrases of the SSIDs must match.
      As long as all of the above points are all met then the Pod should automatically connect to your Hub's Wi-Fi and begin broadcasting. The wireless details from the Pod will be the same as the Hub's details, so no additional steps are required to connect the devices in the home.
      Best,
