- AdduxiVery Insightful Person
If the 2.4Ghz is still working it’s not the VM supply. You need to check why the 5Ghz signal is being interrupted. A WiFi survey should help, there are lots of scanners in the Google Play store. It could also be the Hub’s Channel Optimisation changing channels. In that case disable Optimisation.
- Robert_P
Hello r1igby
Thanks for taking the time to post in regards to the wireless connection issues experienced with your bands, we appreciate you raising this via the forums and welcome to the community.
As Adduxi has alluded, if the issues was with the service itself, neither band would work. Have you been able to follow their advice and steps to see if this helps resolve the issue?
Rob
- Client62Alessandro Volta
Try setting the 5GHz Wi-Fi to channel 36 or 44. ( i.e. Avoiding Auto Channels & DFS Channels )
Related Content
- 1 month ago
- 2 years ago
- 2 years ago
- 1 year ago
