on 07-02-2024 17:10
I’ve just got VM 1Gig to replace Sky broadband. My SkyQ and 2 SkyQ minis are connected via Ethernet (on unmanaged switches) to the Hub. Should I disable the SkyQ mesh (via the engineer settings) or keep it on? Will the minis communicate with the main box via it’s own mesh when passing over recorded / live satellite contents (saving the VM bandwidth) or am I better disabling the wireless capabilities on all the boxes? Thanks.
Answered! Go to Answer
on 07-02-2024 19:20
There have been many posts here about problems with VM Wifi and SkyQ kit. Best to stick to the wired connections and switch IMHO.
on 07-02-2024 19:20
on 08-02-2024 07:57
Thanks. I've gone into the 'secret' Sky menu and disabled Wifi on the 3 sky Q boxes
