james_wager
2 years agoJoining in
Replacement hub 3 not found in app
Replacement hub 3 has been sent and set-up as per instructions. Spent the evening reconnecting all devices to the new WiFi. Everything currently working as it should, but the app can't/won't connect to the hub. It is telling me it can't find the hub in the app. It is also saying it can't connect to the WiFi pods that we need around the house. I have reset the router, done a hard reset for 40 seconds and done everything the FAQs suggest. How do I get it to recognise the router in the app as well as get the pods setup on the new WiFi?
