Re: Hub 3 solid red light.
Julianslapp
I have the same problem, but it's very difficult to get anyone to give a damn about any problems. I reset mine and it is flashing red and white intermittently, all VM do is fob you off. I will be changing supp.iers if someone doesn't help.
1 ACCEPTED SOLUTION
Accepted Solutions
@Julianslapp   Please start your own thread for this topic.  A flashing red and white light is different to a solid constant red light.   Cheers.
4 REPLIES 4
unisoft
Knows their stuff
https://www.virginmedia.com/help/how-to/broadband/hub-lights
Daniel_Et
Hi @Julianslapp 👋 Thank you for your post and welcome to the Virgin Media Community 😀
We're sorry to hear about the problem you're having and the poor experience you've had 😔
Have you tried following the advice provided on the link posted by @unisoft?
If you have and you're still no further forward, please pop back to us at your earliest convenience.
Regards,
Daniel
Hi, the power light is sometimes white, sometimes yellow and sometimes red, I would like a NEW hub, preferably a more modern one as the hub 3 isn't really fut for purpose. I rang 150 and some bloke told me a red light is OK and not to worry, I went on the VM app and ut says it is a sign of overheating, I'm going in circles, (maybe that's what VM intends), do you ever actually solve any problems?
