on 25-02-2024 16:48
This post is kind of saying you shouldn’t be promised a certain mb wifi speed in every room r they will give you the £100 or how much it was the wifi vm promise thing
luckily it’s not true omni direction cheap antennas and cut down versions of hubs that weren’t good before they were rebranded ain’t ever going to to be good
did you know a Cisco business ap or wifi hub can beam a signal through a whole shopping Center ……. Our wifi can’t go to the next room without though a wall
go figure
25-02-2024 17:48 - edited 25-02-2024 17:52
"did you know a Cisco business ap or wifi hub can beam a signal through a whole shopping Center"
I think you will find the type of Wireless Access Point to do this cost well over £1000. Something like this costs £1500 and supports over 1500 users: https://uk.store.ui.com/uk/en/pro/category/all-wifi/products/uwb-xg
VM could certainly offer much better hubs, but unfortunately the down side would be that people’s bill would go up by a large amount. So what they do is provide a system that is just adequate for the largest number of customers, but of course it does not satisfy a growing number of customers. There are also external factors like more people working at home due to/since COVID and the much greater use of streaming rather than linear TV.
25-02-2024 18:02 - edited 25-02-2024 18:11
@LukeLjJames wrote:This post is kind of saying you shouldn’t be promised a certain mb wifi speed in every room r they will give you the £100 or how much it was the wifi vm promise thing
go figure
Why not?
Get pods to ensure you have at least 30Mbps in all rooms of your home? Great.
£100 for not getting the minimum speed? Great.
'Average' consumers get pulled into this sort of stuff and allows VM to bring in more users, and so more money. Great.
Above average consumers understand cheap rented kit is just that, and you need to invest in your own to benefit from faster broadband speeds.
I don't see the issue.
on 25-02-2024 19:04
on 26-02-2024 08:34
It takes two to tango.
It never occurs to folks that Wi-Fi is a two way radio process.
Quite often the poor signal from a tiny antenna in mobile phone or laptop is what lets down the Wi-Fi connection.
