mrthrt
9 months agoTuning in
Hub 5x a bit limited
Finding the Hub 5x a bit limiting - no modem only option, stuck with the 192.168.0.x network, no VPN functionality etc.
Anyone know if it can be replaced with a 3rd party unit ? Really looking for a unit i can flick into modem mode and then fit a pfsense firewall behind the router., Had a look around but cannot seem to find anything with the hub 5x fibre connection (XGS-PON) which looks like a fibre LC type connector but instead of two ends it just has the one.
