on 16-02-2024 10:34
I spoke that he Virgin Media Unity team over the last few days about an update on the availability of modem mode on the Hub 5x used in the Full fibre areas (XGS-PON) and they quiet blatantly said it would not be coming to this devices so if this is a deal breaker for you and you have other ISP options in your areas which are suitable for you then I would suggest you look at them.
I will be leaving at the soonest opportunity
on 16-02-2024 11:25
Guess I die happy with coax and hope VM don't install FFTP to me if I ever get a hub 5 non x 😞
on 16-02-2024 12:07
I very much doubt it, I understand that it’s under test at present.
on 16-02-2024 12:20
We can only hope
on 17-02-2024 08:49
Can this be confirmed?
on 17-02-2024 09:28
One thing I've learned about Virginmedia. Never believe anything they say.
on 18-02-2024 14:09
Thanks for that info. I was waiting for modem mode on the hub 5x. Very disappointing.
on 18-02-2024 14:44
I found this http://192.168.0.1/?page=modemmode
on 18-02-2024 14:49
It doesn't work.
on 18-02-2024 14:49
Your link wont work.
