on 21-05-2024 16:46
.y hub has been red for over 6 months. I've tried to speak to virgin media about and and all they keep saying is that I can get a new hub if I upgrade my package. The Internet connection is so bad, I've done all that has been asked and still it doesn't work properly. Please help me
on 21-05-2024 17:01
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you
on 21-05-2024 17:41
Hello Foggy1983
Sorry to hear of the red LED issue on your Hub 3 and the problems experienced getting this looked into, we're here to help via the forums and welcome to the community.
I will send you a Private Message to get some more details from you to assist. Check the envelope in the top right of the forum when signed in for the message.
Rob
