stephjunco's avatar
stephjunco
6 months ago
Broadband disconnects and speed issues
I have been experience disconnects and speed problems for months. It has caused many problems from being unable to connect to meetings online to my kids experience disconnects while trying to do homework and gaming. I find it has become second nature to just switch the wifi off on my phone because the internet connection on wifi  is constantly dropping or the page loading becomes unbearably slow. I have done the checks on the Virgin Media site and have rebooted the router many times.
I am hoping someone will be able to have a look at the logs from my router to see if there is are any  obvious problem. Thank you for the help.
Stephen
Router =  Hub 3.0
12027500003.238256 qam9
21387500003.537256 qam1
3146750000337256 qam2
41547500002.738256 qam3
5162750000338256 qam4
6170750000338256 qam5
71787500003.238256 qam6
81867500003.438256 qam7
91947500003.238256 qam8
10210750000338256 qam10
112187500002.738256 qam11
122267500002.738256 qam12
132347500002.738256 qam13
142427500002.538256 qam14
152507500002.938256 qam15
162587500003.238256 qam16
173307500004.638256 qam25
183387500004.638256 qam26
193467500004.538256 qam27
203547500004.638256 qam28
213627500004.840256 qam29
223707500004.538256 qam30
233787500004.538256 qam31
243867500004.438256 qam32
1Locked38.94190
2Locked37.652775
3Locked37.62639
4Locked38.61559
5Locked38.62889
6Locked38.61490
7Locked38.61140
8Locked38.92400
9Locked38.95220
10Locked38.62258
11Locked38.61500
12Locked38.91420
13Locked38.61940
14Locked38.92010
15Locked38.91660
16Locked38.61290
17Locked38.9920
18Locked38.9840
19Locked38.9830
20Locked38.9780
21Locked40.3670
22Locked38.9580
23Locked38.6400
24Locked38.9400
  • Upstream bonded channels
    13659999047512064 qam3
    22360002947.5512064 qam9
    33009997547.3512064 qam4
    44310002447512064 qam2
    54960000047512064 qam1
    1ATDMA0050
    3ATDMA0000
    4ATDMA0000
    5ATDMA0000
    02/08/2024 01:32:8criticalTFTP file complete - but missing mandatory TLV;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/08/2024 01:31:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/08/2024 01:21:28criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/08/2024 01:19:39Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/08/2024 01:19:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/08/2024 01:19:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/08/2024 01:19:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    31/07/2024 06:02:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    31/07/2024 03:08:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    27/07/2024 16:13:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    27/07/2024 15:08:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    24/07/2024 04:50:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    24/07/2024 03:08:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    20/07/2024 21:23:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    20/07/2024 15:08:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    18/07/2024 04:46:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    17/07/2024 16:21:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    17/07/2024 16:21:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    17/07/2024 05:34:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    Thinkbroadband Link
    https://www.thinkbroadband.com/broadband/monitoring/quality/share/c8a1ee112fe7f65ca0a054d157a6a4c57ffdfc47
    • Cardiffman282's avatar
      Cardiffman282
      Trouble shooter
      Looks like it was a busy night on the error front. Maybe it was attempting a firmware update but failing. Perhaps try a 60 second pinhole reset of the hub.
      • stephjunco's avatar
        stephjunco
        Hi thanks for the reply. Yes, the broadband was down early in the morning because of work that Virgin was having done in my area. My alarm started beep loudly when it detected no phone services.  I have taken your advice to reset the router once again but I am pretty doubtful that this will fix months of frustration.
    Having Smart Wi-Fi enabled and having Wi-Fi Auto Channels enabled causes random dropouts for our Hub 3 because the Hub 3 is quite slow to change Wi-Fi channels.
    Try with  ... ( yes I have disabled Wi-Fi modes for kit that was made 15+ years ago )
    • Matthew_ML's avatar
      Matthew_ML
      We understand this is frustrating and we are sorry for any issues caused in this time,
      The outage has now ended, has the service improved at all?
