8 diget pin
Sully2
Trying to find 8 diget pin on router but is not on base only setting number I can see is 192.168.0.1
29 REPLIES 29
goslow
A Hub 5 label is shown here
https://community.virginmedia.com/t5/Forum-Archive/Hub-5-web-interface-password/m-p/4856213#M2934633
the settings password is underlined in red which is 12 characters to log into the Hub 5
SSID and wifi password are on the LHS of the sticker and are redacted in white
Sully2
ok thanks will go and try it now
Sully2
Have just tried and it specifies 8 digit pin and will not accept letters at all
goslow
1) Does your label on the bottom of your Hub 5 look like the one in the image I linked?
2) Does it show the 'Sagemcom' brand name?
3) Does your sticker underneath show a 12 character password for your own hub?
Sully2
Yes it is identical made by the same company Sagemcom in France
goslow
Is the prompt asking you for a WPS 8 digit number which may well be in a pull-out card in a little pouch on the side or back of the hub?
Sully2
It asks for an 8 digit number have looked on the side and can't see a pouch
goslow
Post up a screen shot of what you are seeing. Use the camera icon to insert an image when you are composing a message
The moderators will have to approve it before it appears on the public forum.
Sully2
I have a chromebook and  the camera facility yo show doesn't seem available
Sully2
Can I email or message you is that allowed?
