- Client62Alessandro Volta
I am assuming that you are switching from WiFi to network cable with the PS when it is not doing any internet based tasks.
Try this page ...https://www.playstation.com/en-gb/support/error-codes/ps5/ce-109503-8/
- simon123321Joining in
Basically I have no issue with connecting to Wifi
tried the fix from playstation and I am able to obtain IP address now, proofing there is some block from my modem itself?
Nothing has proved it is a Hub 3 issue.
The WiFi and Ethernet connections should both work ( always assuming the network cable is not defective ).
Unless some port forwarding is configured on the Hub that directs data to the PS5's WiFi IP address.
- Finn3Joining in
I was just having this issue. PS5 connected via LAN then just stopped working. Would work on WiFi no issues.
Logged into WiFi router using IP address and password on bottom of the router itself and found that the PS5 LAN had been put onto a MAC Address Filtering list, essentially blocking access. This is found in the Security menu on the left hand side under MAC Filtering. Not sure why or how this happened, maybe from an update on the router or something.
Deleted it from the list and works fine now.
- AdduxiVery Insightful Person
This is how the Connect app "pauses" devices. It may have originated from there? We have seen posts here where devices have been paused via the app, and the users have had to do this procedure to "unpause" them.
- Finn3Joining in
I have never really used the app much, I did check it to see if anything was paused/blocked but didn't see anything.
I might have just missed it though and took the long route around it haha 👍
Related Content
- 1 year ago
- 1 year ago
