PaulS1962's avatar
PaulS1962
6 months ago
Power Unit
My Virgin Stream Power Unit (the one with the ethernet socket) has stopped working correctly. I have checked the leads/sockets etc and all are okay. It is an intermittent fault. Can I get a replacement from Virgin Media?
  • Tudor's avatar
  • I am lucky that I have never come across this problem myself as I have only used the Wi-Fi on my unit.  The only way that I think you will get an answer to your problem is to keep contacting Virgin until you get the satisfaction that you want.  Unfortunately this can sometimes take some time if you don’t get through to someone who really wants to help you.
