- jpeg1Alessandro Volta
Are you looking on a email app, or on webmail?
Using webmail, check all folders including deleted/junk.
Also check if you have any filters set. If the emails are not there, they are likely lost. VM don't keep backups, hopefully you will have at least some. Good luck!
- legacy1Alessandro Volta
This is why I use Thunderbird
This is why I don't use VM email.
- Sabrina_BForum Team (Retired)
Hi TonyH123 👋.
Thanks for reaching out to us and welcome to the Community Forums. Apologies for the issues that you are having with your emails. So that we can look into this for you, please can you join me in a private message.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
- AngrybirdmeOn our wavelength
Im having the same problems....my inbox is EMPTY!!! I DIDNT DELETE THEM EITHER!
- Martin_N
Hi Angrybirdme,
Thank you for your post. We're sorry to hear about the emails missing.
I appreciate you have confirmed that you didn't delete them yourself but have you been able to check your deleted inbox to see if they have been moved there?
^Martin
Related Content
- 1 year ago
- 1 year ago
- 1 year ago
- 2 years ago
- 3 months ago
