johnbrig's avatar
johnbrig
3 months ago
WiFi pod solid blue light
one of my black WiFi pods has stopped working (previously fine) and shows o constant blue light. If I disconnect and then plug back in, it still just shows solid blue light. Similarly when I have performed a factory reset with a pen.
i have placed the pod next to the router and have rebooted the router, but nothing changes.
My other WiFi pod is fine.
can anyone help?
  • Thanks for reaching out to us johnbrig, and welcome back to our Community Forums!
    Looking into this for you, and focusing on our Black Wi-Fi pods, when connecting your devices to your network using the WPS button, a slow pulsing blue light will appear. This light will turn solid blue once a WPS connection is successful.
    If the light starts blinking rapidly it means the WPS connection was unsuccessful, and you should try again.
    If a solid blue light appears and you haven’t pressed the WPS button, don’t worry, this can also indicate that your WiFi Pod is booting up.
    Can you confirm if the Wi-Fi pod is currently working as expected and/or if there's been any changes in the lights on the Wi-Fi pod? Have you pressed the WPS button at all?
    David_Bn
    • johnbrig's avatar
      johnbrig
      The pod isn’t working as expected. It just shows a constant blue light no matter what I do (reset, switch off, WPS etc). There is no blinking light. However Virgin are sending me a replacement pod so hopefully that will sort it.
      • Robert_P's avatar
        Robert_P
        Thanks for the update johnbrig, has the replacement pod been received since you post? If so, is it connected and working?
    WPS surely not.
    VM have to re-pair the not working VM Pods to your VM Hub.
