scarter177's avatar
scarter177
WiFi Pod (Black) LED cycling through all colours?
Hi all, I received a WiFi Pod (Black) early last week from VM & set it up using the VM Connect app. It's placed halfway between the Hub5x router and my WiFi dead spot in my living room. Over the last few days it's LEDs have just been cycling all the colours within the space of 5 mins or so. Going from: Solid White, Flashing White, Solid Green, Flashing Green, Solid Blue, Flashing Blue, etc. I have tried turning the pod on/off and resetting it, but it's still doing the same. Any ideas?
  • Carley_S's avatar
    Carley_S
    Hi scarter177
    Welcome back to the community forums
    Sorry to hear you're having issues with your WiFi pod at this time.
    I can see that one of my colleagues is already supporting you on this through a private message, should you've any further concerns or questions, please reach out via your already opened private message and they'll be able to assist you further from there.
  • Sephiroth's avatar
    Sephiroth
    If you take the pod to the Hub 5x, connect it by Ethernet cable, what do the lights do?
