tbate's avatar
tbate
Just joined
11 months ago
Wifi drops despite 3+ technician visits...
I'm experiencing an intermittent connection error which drops all connections for all computers, even with some computers disconnected it appears to still have the same effect. It's not specific to one NIC erroring. I'm providing all of the troubleshooting information I can in the hopes that anybody is able to help me pinpoint what's causing these issues.
This is what my outage chart for a typical day looks like, the unpredictable outages are making WFH next to impossible.
And here's the corresponding router logs and upstream/downstream. I've censored MAC addresses for obvious reasons.
14110000003.740256 qam1
2419000000438256 qam2
34270000003.538256 qam3
44350000003.738256 qam4
54430000003.938256 qam5
64510000004.338256 qam6
74590000003.738256 qam7
8467000000440256 qam8
95390000005.540256 qam17
10547000000540256 qam18
115550000005.338256 qam19
125630000005.438256 qam20
135710000005.640256 qam21
145790000005.940256 qam22
155870000005.638256 qam23
165950000005.540256 qam24
176030000005.840256 qam25
186110000005.340256 qam26
196190000004.840256 qam27
206270000004.538256 qam28
216350000004.538256 qam29
226430000004.538256 qam30
236510000004.638256 qam31
246590000004.840256 qam32
Downstream bonded channels (Errors)
1Locked40.9178948196
2Locked38.920810
3Locked38.928220
4Locked38.9395961515
5Locked38.950220
6Locked38.953640
7Locked38.661890
8Locked40.359190
9Locked40.380650
10Locked40.391070
11Locked38.9109690
12Locked38.9111290
13Locked40.396930
14Locked40.3135700
15Locked38.9149930
16Locked40.3165970
17Locked40.3192170
18Locked40.3206160
19Locked40.9231140
20Locked38.9266790
21Locked38.9245520
22Locked38.9197940
23Locked38.9143520
24Locked40.3104280
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
14960000046512064 qam1
23660000045.5512064 qam3
32360000044.8512032 qam5
43009996545.5512064 qam4
54310000045.3512064 qam2
Upstream bonded channels (Timeouts)
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0010
4ATDMA0010
5ATDMA0010
3ATDMA0010
4ATDMA0010
5ATDMA0010
Log Data
TimePriorityDescription
05/05/2025 02:31:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2025 02:22:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/05/2025 02:14:3criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2025 22:38:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2025 22:27:31criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2025 21:53:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2025 21:46:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2025 18:53:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/05/2025 18:39:20criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • Hey tabate, thank you for reaching out and a warm welcome to the community, we are sorry to hear you are having some connection issues.
    Let me send you a DM to find out what has been going on.
  • Tudor's avatar
    Stats like that do indicate noise ingress and would definitely need a technician’s visit to correct.
    The figures are accumulative since the hub was last power cycled. So please turn off your hub for a short period, this will reset the counters, then post a new full set of stats after about two hours. This will indicate the current line status.
