Magsfedupwithvm's avatar
Magsfedupwithvm
WIFI 2.4ghz help
Need help
how do I check to see what Wi-Fi Ime on as I have all these smart plugs and they need to be run off 2.4ghz for them to work since I have received this new hub they won’t connect to the Wi-Fi after tried researching it but don’t seem to be getting any where I must say that Ime not very technical with this sort of stuff
  • Need help
    Login to the VM Hub menu and turn off the 5GHz Wi-Fi for a period of time.
    This is the simplest way to ensure all your kit is on the same 2.4GHz band.
    Another practical approach is to set the Wi-Fi SSID/Password of the new VM Hub to be the same as the previous VM Hub, this reconnects devices quickly and without needed to re-connect one at a time.
    • Magsfedupwithvm's avatar
      Magsfedupwithvm
      Thank you for your speedy reply but Ime not technical so I don’t know how to get into my vm hub
      • jbrennand's avatar
        See this...
        ___________
        In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
        Or... if you have to login just follow the login details pathway.
        Then navigate to the wireless pages.
