StreetGlide168's avatar
Wi-Fi Pods Ordering problem
Hi, I can't find an obvious way to order wi-fi pods. I am on 1 Gig and the VM Connect app is showing 8 Mbps in 2 back bedrooms and constantly drops out, but doesn't offer the option to order a wi-fi pod. Chat-to-us-online isn't working either. Can someone help please?
  • See this for ways to try...
    ___________________
    There are a few options. Firstly call it in on the “faults” line - on 150 (VM Phone - free) or 0345 454 1111 (any other phone - national rate). Use option 2 (faults), dont press any other buttons when offered and you should be in the queue for the next agent.
    If you get cut off after an automated reboot cycle, just call back in a couple of minutes as the system should know that you have just been on and it hasn’t helped and put you in the queue.
Try now, but calling at 08.00 midweek (09.00 Sun) is the best time to get through quickly at busy/closed times you may get redirected to offshore - hence calling early is best.
    You can text VM on 0753 305 1809 include account name/number and what the issue is, there is also a “Chat” option on their website - but note that replies usually take longer. Or you can speak to the team on WhatsApp by logging into your online account via a mobile handset and there will be a link to speak to VM by Whats App (the number is 0780 3089 684 ) - you can use the same number for their other social media platforms too (TwitX/Fbook. etc) - so try them all.
    FINALLY… A VM person will pick this up on here and respond, but it can take a few days for them to get here.
  • jbrennand's avatar
    ___________________
    • StreetGlide168's avatar
      StreetGlide168
      Many thanks for the detailed reply! I eventually used chat and got through very quickly and ordered a pod - it arrived withing 3 days and has solved the poor speeds upstairs.
      Cheers, John
