Mucky1's avatar
Mucky1
1 month ago
"Virgin" Calls Re Web/WiFi Issue
I have been receiving occasional unsolicited calls purporting to be from Virgin re an internet/wi-fi/router problem at my house. I find them suspicious and think I could be being scammed in some way, so I tend to be slightly awkward with the caller (but not rude) and they tend to hang up immediately, which in itself seems suspicious.
My service seems to be running largely OK. However my Hub 3 router DOES show a continuous red light these days. I think I've read that this could be indicative of an overheating problem and it's possible Virgin have detected this and are trying to contact me because it's a possible fire issue.
Could somebody at Virgin check this for me?
  • Thanks once more Alessandro, you have gone well out of your way and covered all the ends. You are clearly a credit to the Virgin Community. I will sign off here and see about getting a replacement routerto eliminate the possible overheating issue.
    • Lee_R's avatar
      Lee_R
      Hi Mucky1 thanks for your update.
      Are you needing me to look into getting you a replacement hub? If so, please do get back to me and I will then send you a private message, so that I can take a look on your behalf.
      Lee_R
      • Mucky1's avatar
        Mucky1
        Hi Lee, thanks for getting back to me on this. I had lots of helpful advice from "Goslow" but it left the issue of the red (warning?) light on the Hub3. As far as I can see the router is functioning OK (speed, continuity etc) but I read somewhere that the red light is a possible indication of overheating and therefore a risk of fire, and I think I also read that Virgin themselves would REQUIRE the unit to be changed in this case. So yes, I think we should go ahead with replacement if possible.
        Kind Regards
  • Thank-you for a clear reply and the advice Alessandro, I will try one or more of your options.
    By the way, do you know how the scam would work if I engage the caller?
    • goslow's avatar
      goslow
      The scam works in various ways but one of the most common is that the callers try to convince you of a problem with your VM connection. They offer to 'fix' the (imaginary) problem by installing remote access software on your device which allows them to take control of it.
      Once they have done that they may try to access your online banking, commit identity theft, try to take ownership of your device/account, lock your device and demand a fee to unlock it etc. etc.
      VM will not ring you out of the blue to tell you of a technical issue. When the scammers call back (as they inevitably will) just hang up on them without talking to them. Now they have identified your number is working and you are willing to talk to them, they will almost certainly try again (and may present as another organisation such as Amazon, Microsoft etc.)
      Here are some links from the Met Police to booklets in an easy-to-read format without jargon on how various scams are run
      https://www.met.police.uk/SysSiteAssets/media/downloads/central/advice/fraud/met/little-booklet-of-phone-scams.pdf
      https://www.met.police.uk/SysSiteAssets/media/downloads/central/advice/fraud/met/the-little-book-of-big-scams.pdf
      • Mucky1's avatar
        Mucky1
        Thanks again for your help and links which I'll be printing off. I am acutely sceptical of any unsolicited calls myself, but my wife is slightly less so as she gets wi-fi drop-outs in her office area and is all too ready to connect the "Virgin" calls to that, although the drop-outs are almost certainly on "our side of things". We may have some additional protection in as much as the calls are to a landline, so at least we can't be panicked into pressing any smartphone buttons.
  • goslow's avatar
    goslow
    The unsolicited calls are a scam. The red light on a Hub 3 indicates an overheating problem which normally involves replacing the hub.
    You would normally get a reply on here from a VM person within a few days but the forum is going offline next week to migrate and merge with the O2 community forum so any comm's are likely to be delayed.
    You could try your luck phoning in (most likely you will get the run around without any useful help) or, if the red light is not associated with any problems at present, wait for a VM person on here when the forum comes back online.
