Yorky46's avatar
Yorky46
1 month ago
Unable to reserve an IP address on Hub 5
I have a couple of devices which I'd like to use a static IP address.
I went to the DHCP page and added a rule for one but when I went to reserve the second I get an error...
"Sorry! There was an error while updating your settings. Please try again a bit later".
I have tried a bit later and also switched the Hub off for a while but I still get the same error. I tried phone support but that was a joke. The chap at the other end clearly had no idea what I was talking about and his advice was to try later.
I know I can apply a static IP individually to my device within it's own settings but I'd would prefer to do it this way for future use.
Any ideas?
  • legacy1's avatar
    Put simply the hub settings are not well tested and they don't to be you just need modem mode and your own router.
  • Roger_Gooner's avatar
    Roger_Gooner
    Valid point Tudor, and static addreses can only be set for a fraction of devices in a typical home - another reason why I don't recommend trying to use them. And as for setting them: always outside the DHCP reservation range.
    • Tudor's avatar
      I do not use many old type IoT devices, replaced most with Waveshare 8 channel Ethernet Relay modules Modbus TCP protocol and PoE. I have written some C code to drive them. Have 4 in use.
      Yes, my statics are usually on switches, AP's etc. and as you say, outside the DHCP scope.
  • Tudor's avatar
    Reserved IP addresses are NOT static IP addresses. You can only set static IP addresses in a device. Reserved IP addresses as most people seem to believe as being static are not totally static and can in certain instances can be reused by the DHCP server.
      Tudor​   Sorry, but enlighten me please. I always thought Reserved IP's couldn't be reused and were tied to a MAC address?
        Roger_Gooner
        A reserved IP address is tied to a MAC address in the hub whereas a static IP is set on the device. I strongly suspect the reason why VM has such a big default DHCP reservation range of 236 address from 192.168.0.10 to 192.168.0.245 is so that even the most tech-heavy home will never run out of addresses and blame VM when the "Limited Connectivity" error comes up.
        For the tech savvy users who want to set static IP addresses without changing the DHCP reservation range for their managed switches, servers, etc, they can use .2 to .9 and .246 to .254. Note that .0, .1 and .255 are not used.
    Roger_Gooner
    The hub's Active Lease Table hasn't cleared down, so note the second device's MAC address and IP address, turn off the the second device, reboot the hub and reserve the same IP address for the second device.
  • Thanks for all the replies.
    I can confirm the IP's are within the range of the IP scope. The HUB has assigned the IP address and I'm just trying to keep it static so I can access the device through routes without having to be concerned that the IP address may have changed.
    I'm using the Hub to add a rule and it worked perfectly for the first device but, when I try to do the exact same thing with the second device, it throws up an error.
    It's more of an annoyance than anything else and I may just end up assigning the IP through the device itself.
    thanks again
    • Muhammod_I's avatar
      Muhammod_I
      Thanks for reaching out to us with this Yorky46 and I'm sorry that you're having a difficult time with this.
      Can I ask if you've tried the steps provided by our forum members and had any luck?
      If you need any further support after this, please don't hesitate to reach out.
      We're more than happy to help 🙂
      Just one thing to try.  Add the IP addresses in numerical rising order, from memory a good while ago, there was an issue when things had to be done in numerical order, or it wouldn't work.  I think it may have been port forwarding though?
      Also try setting the DHCP scope much smaller, e.g. x.x.x.100 to x.x.x.150  Maybe worth a try?
    Hmm, I’ve lots of Reserved IP’s in use, as well as a few static ones.  Don’t use a VM router though, but I wouldn’t recommend one way against the other as far as IP issuing.  I also keep my DHCP scope as small as possible.
    Roger_Gooner
    You are on the right path and I really don't recommend static addresses for residential users. The DHCP reservation range is 192.168.0.10 to 192.168.0.245, and you should reserve your IP address within this range. By reserving an IP address within the hub's settings, you centralise your network management. The hub's DHCP server is smart enough to 'earmark' these addresses, so it won't dynamically assign them to other devices and cause a conflict.
    Let's say your devices have dynamic addresses of 192.168.0.11 and 192.168.0.12, and this is the easiest way to proceed. You find the MAC addresses and enter the MAC address and 192.168.0.11 for the first device and click Add rule. This should work and you do the same for the other device with its MAC address and 192.168.0.12.
    The most reliable way to get your devices reconnected is to turn them off, switch the hub off at the wall socket, wait two minutes and switch back on. Once the hub has fully rebooted (takes some minutes to get a solid white light), switch the devices back on and they will be forced to send a "DHCP Request". The hub will respond with the newly reserved IP addresses.
    It is much better to set the Static IPs on each of the devices
     i.e. via the device's settings screen or web management page.
    Use the IP range 192.168.0.2 to 192.168.0.9 - extend this if needed by moving the DHCP start point to say 192.168.0.30
    Using a  "Reserved IP" is not quite the same as the devices remain dependent on the VM Hub's DHCP server working correctly.
    Also when the VM Hub is Factory Reset or replaced all Reserved IPs are lost.
    Are the reserved IP's inside the DHCP scope?
