Sweden's avatar
Sweden
Synology thru Hub3 via Draytek 2927
My Synology NAS (latest fixes on DSM 7.2.1) reports 2 routers in my network and that prevents certain functions from working.  An example being getting a Certificate from Let's Encrypt - it fails whilst doing a network check.
Synology suggest set one of the routers to Bridge Mode.
SSH into the NAS and "traceroute 8.8.8.8" starts at 192.168.0.1 (the Draytek 2927) then goes to 10.53.39.33 which, I can only assume, is the VM Hub-3 before progressing into:
 sigl-core-<stuff>
.network.virginmedia.net   at a  62.252.  address
The Hub3 is operating in Modem mode.  Login to 192.168.100.1 and I can verify that. but I see nowhere in the menu where I can switch it to Bridge Mode.
My next port of call is switch it back to Router mode and maybe then I can set bridge mode.
Has anyone any experience of this and perhaps a successful way forward.
BTW, I can't set the Draytek to Bridge mode as it hosts multiple VLANs.
Any guidance greatly appreciated.
1 Reply
  • legacy1's avatar
    modem mode is bridge mode the 10. is by VM gateway not by hub
    if Synology NAS is doing a traceroute and thinking  2 routers are in the network then it is wrong
    any problem you have are down to your router
