Cally_18's avatar
Cally_18
14 days ago
Quick Question re POD
I’m due a new router this Friday, will my existing POD be configured to my new router before I set it up as obviously it’s working now with the router that will due to be unplugged?
  • Cally_18's avatar
    Cally_18
    Ok, new hub arrived and after reading on here somewhere it may need activating, correct! Called up and all went to plan. Asked about the pod and also was told should work again straight away. Plugged it in and all systems go 😄
      Nice to get a positive response !
    This is why we bought a pair of Wi-Fi Access Points and configured them to keep working regardless of which Hub VM supply.
    • jpeg1's avatar
      jpeg1
      ... and regardless of your broadband supplier.
    VM usually omit to re-pair the VM Pods to the replacement Hub.
