2 months agoAlessandro Volta
Login to the VM Hub menu and find out, don't assume the answer is No !
pd0411
2 months agoJoining in
Sorry total novice, I.m logged in but where would I need to check?
- Tudor2 months agoVery Insightful Person
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
- Click on the “> Check router status” button
- Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
- Click on the “Upstream” tab, copy the text and paste into your reply
- Click on the “Networking” tab, copy the text and paste into your reply.
- Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
- pd04112 months agoJoining in
3.0 Downstream channels
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID1 195000000 11.1 41 QAM 256 8 2 139000000 12.5 41 QAM 256 1 3 163000000 11.5 41 QAM 256 4 4 171000000 11.2 41 QAM 256 5 5 203000000 10.8 41 QAM 256 9 6 211000000 10.7 41 QAM 256 10 7 219000000 10.6 41 QAM 256 11 8 227000000 10.7 41 QAM 256 12 9 235000000 10.5 41 QAM 256 13 10 243000000 10.2 41 QAM 256 14 11 259000000 10.2 41 QAM 256 16 12 267000000 10.4 41 QAM 256 17 13 275000000 10.1 41 QAM 256 18 14 283000000 9.6 41 QAM 256 19 15 291000000 9.1 41 QAM 256 20 16 299000000 9 40 QAM 256 21 17 307000000 9.3 40 QAM 256 22 18 315000000 9.5 40 QAM 256 23 19 323000000 9.5 40 QAM 256 24 20 331000000 9.5 40 QAM 256 25 21 339000000 9.9 40 QAM 256 26 22 347000000 10.1 41 QAM 256 27 23 355000000 9.9 41 QAM 256 28 24 363000000 9.7 41 QAM 256 29 25 371000000 9.6 41 QAM 256 30 26 379000000 9.9 41 QAM 256 31 27 387000000 10.2 41 QAM 256 32 28 395000000 10.3 41 QAM 256 33 29 403000000 10.3 41 QAM 256 34 30 419000000 10.3 41 QAM 256 36 31 427000000 10.1 41 QAM 256 37 32 451000000 9.6 41 QAM 256 40 3.0 Downstream channels
Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors1 Locked 41 0 0 2 Locked 41 0 0 3 Locked 41 0 0 4 Locked 41 0 0 5 Locked 41 0 0 6 Locked 41 0 0 7 Locked 41 0 0 8 Locked 41 0 0 9 Locked 41 0 0 10 Locked 41 0 0 11 Locked 41 0 0 12 Locked 41 0 0 13 Locked 41 0 0 14 Locked 41 0 0 15 Locked 41 0 0 16 Locked 40 0 0 17 Locked 40 0 0 18 Locked 40 0 0 19 Locked 40 0 0 20 Locked 40 0 0 21 Locked 40 0 0 22 Locked 41 0 0 23 Locked 41 0 0 24 Locked 41 0 0 25 Locked 41 0 0 26 Locked 41 0 0 27 Locked 41 0 0 28 Locked 41 0 0 29 Locked 41 0 0 30 Locked 41 0 0 31 Locked 41 0 0 32 Locked 41 0 0 3.1 Downstream channels
Channel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)159 94 4K 1840 QAM 4096 1108 3.1 Downstream channels
Channel ID Locked Status RxMER Data (dB) PLC Power (dBmV) Corrected errors (Active Profile) Uncorrectable errors (Active Profile)159 Locked 40 4.6 201742214 0 Upstream
Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID0 49600000 44.3 5120 QAM 64 1 1 43100000 44.3 5120 QAM 64 2 2 36600000 43.8 5120 QAM 64 3 3 30100000 43.3 5120 QAM 64 4 4 23600000 42.8 5120 QAM 64 5 3.0 Upstream channels
Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts0 ATDMA 0 0 0 0 1 ATDMA 0 0 0 0 2 ATDMA 0 0 0 0 3 ATDMA 0 0 0 0 4 ATDMA 0 0 0 0 3.1 Upstream channels
Channel Channel Width (MHz) Power (dBmV) FFT Type Modulation6 10 38.2 2K QAM 256 3.1 Upstream channels
Channel Channel Type Number of Active Subcarriers First Active Subcarrier (Hz) T3 Timeouts T4 Timeouts6 OFDMA 200 74000000 0 0 Network Log
Time Priority Description02-01-2025 19:02:39 notice GUI Login Status - Login Success from LAN interface 02-01-2025 17:07:35 notice CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: 431119; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:07:31 warning Unicast DSID PSN startup error 02-01-2025 17:07:25 notice US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:07:25 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:07:20 notice REGISTRATION COMPLETE - Waiting for Operational status 02-01-2025 17:07:14 warning REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:07:14 warning Dynamic Range Window violation 02-01-2025 17:07:14 warning RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:07:09 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:07:08 notice TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:07:01 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:06:59 notice Honoring MDD; IP provisioning mode = IPv4 02-01-2025 17:06:47 critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 02-01-2025 17:06:46 critical Cable Modem Reboot because of - HW or Power-On Reset 29-12-2024 02:54:13 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 29-12-2024 02:54:13 critical 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 29-12-2024 02:52:13 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 29-12-2024 02:49:34 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 26-12-2024 06:44:02 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 26-12-2024 06:40:46 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 26-12-2024 06:39:31 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 25-12-2024 07:38:16 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 25-12-2024 07:34:59 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 21-12-2024 11:34:47 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 21-12-2024 11:31:35 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 21-12-2024 11:31:30 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 19-12-2024 05:52:40 critical Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 19-12-2024 05:52:40 critical 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 19-12-2024 05:50:21 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 19-12-2024 05:48:43 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 14-12-2024 10:50:00 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; 14-12-2024 10:46:44 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Related Content
- 12 months ago
- 3 months ago
