Submersed2640's avatar
Submersed2640
New Hub 5 Not Working With Single Wifi Pod
Hi, I was sent a Hub 5 in the post, hub is activated & it is working well. My single wifi pod no longer works though & in the connect app it says it is offline. The pod was working fine with the Hu...
  • fizz's avatar
    I think they have to be reset but virgin to pair with your new hub... I don't think it is something you can do. I am sure the guys from VM will be along eventually to help you out. may be quicker phoning to be honest
