AlanOHara's avatar
AlanOHara
3 days ago
Lots of T3 timeout errors
Hi I am getting lots of T3 timeout errors on my hub 4, here are the logs:
3.0 Downstream channels
25331000000-6.70000135.779911QAM25625
1139000000-6.00000035.083549QAM2561
2147000000-6.70000135.595078QAM2562
4163000000-7.40000234.925610QAM2564
5171000000-7.50000035.595078QAM2565
6179000000-7.70000135.595078QAM2566
7187000000-8.00000035.083549QAM2567
8195000000-8.29999935.083549QAM2568
9203000000-6.50000035.595078QAM2569
10211000000-5.70000135.779911QAM25610
11219000000-6.00000035.595078QAM25611
12227000000-6.00000035.595078QAM25612
13235000000-6.00000035.779911QAM25613
14243000000-6.00000035.779911QAM25614
15251000000-6.20000135.595078QAM25615
16259000000-5.90000235.779911QAM25616
17267000000-6.29999935.779911QAM25617
18275000000-6.70000135.595078QAM25618
19283000000-7.20000135.595078QAM25619
20291000000-8.29999935.595078QAM25620
21299000000-8.70000135.083549QAM25621
22307000000-7.00000035.595078QAM25622
23315000000-6.70000135.779911QAM25623
24323000000-6.50000035.779911QAM25624
26339000000-6.50000035.779911QAM25626
27347000000-6.20000135.779911QAM25627
28355000000-6.09999835.779911QAM25628
29363000000-6.09999835.779911QAM25629
30371000000-6.09999835.779911QAM25630
31379000000-6.20000135.779911QAM25631
32387000000-6.20000136.386890QAM25632
ChannelLock StatusRxMER (dB)Pre RS ErrorsPost RS Errors
25Locked35.77991100
1Locked35.08354900
2Locked35.59507800
4Locked34.92561000
5Locked35.59507800
6Locked35.59507800
7Locked35.08354900
8Locked35.08354900
9Locked35.59507800
10Locked35.77991100
11Locked35.59507800
12Locked35.59507800
13Locked35.77991100
14Locked35.77991100
15Locked35.59507800
16Locked35.77991100
17Locked35.77991100
18Locked35.59507800
19Locked35.59507800
20Locked35.59507800
21Locked35.08354900
22Locked35.59507800
23Locked35.77991100
24Locked35.77991100
26Locked35.77991100
27Locked35.77991100
28Locked35.77991100
29Locked35.77991100
30Locked35.77991100
31Locked35.77991100
32Locked36.38689000
3.1 Downstream channels
ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
33964K1840QAM4096759
Channel IDLock StatusRxMER Data (dB)PLC Power (dBmV)Correcteds (Active Profile)Uncorrectables (Active Profile)
33Locked38-4.316271557114
  • gitty's avatar
    gitty
    At first glance, I thought the 3.1 upstream power was way too high, compared to the 3.0 upstream, but searching the forum, it looks like a display difference (bug'ish) in the hub 4's firmware. It is many dB higher than how hub 5 displays it. :-)
    Are you getting packet loss?
    • AlanOHara's avatar
      AlanOHara
      Hi gitty, thanks for the reply, not getting any packet loss, I have had one t3 error since removing the attenuator, I'll keep an eye on the network log and see how I go
      • Vikki_M's avatar
        Vikki_M
        Hi AlanOHara,
        Please ensure that the Hub location has good ventilation and there's nothing covering the Hub itself.
        Are you having any connection issues? If so, is this affecting devices connected via Ethernet, WiFi or both please?
        Does this affect multiple devices?
        Are you using any 3rd party networking equipment?
        Please pop back to us when you can.
  • 3.0 Upstream channels
    ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
    13010000042.5205995120 KSym/sec64QAM4
    23660000042.7705995120 KSym/sec64QAM3
    34960000043.2705995120 KSym/sec64QAM1
    44310000043.0205995120 KSym/sec64QAM2
    52360000042.5205995120 KSym/sec64QAM5
    ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
    1US_TYPE_ATDMA0000
    2US_TYPE_ATDMA0000
    3US_TYPE_ATDMA0000
    4US_TYPE_ATDMA0000
    5US_TYPE_ATDMA0000
    3.1 Upstream channels
    ChannelChannel Width (MHz)Power (dBmV)FFT TypeModulation
    610.447.12KQAM128
    ChannelChannel TypeNumber of Active SubcarriersFirst Active Subcarrier (Hz)T3 TimeoutsT4 Timeouts
    6OFDMA20853.400
  • Removed the attenuator, here are the logs:
    253310000004.19999736.609653QAM25625
    11390000004.30000335.779911QAM2561
    21470000003.70000135.595078QAM2562
    31550000003.20000135.779911QAM2563
    41630000003.09999835.779911QAM2564
    51710000003.09999835.779911QAM2565
    61790000003.00000035.595078QAM2566
    71870000002.59999835.779911QAM2567
    81950000002.20000135.779911QAM2568
    102110000004.69999736.609653QAM25610
    112190000004.59999836.609653QAM25611
    122270000004.40000236.386890QAM25612
    132350000004.19999736.386890QAM25613
    142430000004.30000336.386890QAM25614
    152510000004.30000335.779911QAM25615
    162590000004.50000036.609653QAM25616
    172670000004.09999836.609653QAM25617
    182750000003.70000136.609653QAM25618
    192830000003.40000236.386890QAM25619
    202910000002.40000235.779911QAM25620
    212990000002.00000035.595078QAM25621
    223070000003.50000036.386890QAM25622
    233150000004.09999836.386890QAM25623
    243230000004.40000236.609653QAM25624
    263390000004.09999836.609653QAM25626
    273470000004.80000336.609653QAM25627
    283550000004.90000236.609653QAM25628
    293630000004.59999836.386890QAM25629
    303710000004.80000336.386890QAM25630
    313790000004.59999836.609653QAM25631
    323870000004.90000236.386890QAM25632
    25Locked36.60965300
    1Locked35.77991100
    2Locked35.59507800
    3Locked35.77991100
    4Locked35.77991100
    5Locked35.77991100
    6Locked35.59507800
    7Locked35.77991100
    8Locked35.77991100
    10Locked36.60965300
    11Locked36.60965300
    12Locked36.38689000
    13Locked36.38689000
    14Locked36.38689000
    15Locked35.77991100
    16Locked36.60965300
    17Locked36.60965300
    18Locked36.60965300
    19Locked36.38689000
    20Locked35.77991100
    21Locked35.59507800
    22Locked36.38689000
    23Locked36.38689000
    24Locked36.60965300
    26Locked36.60965300
    27Locked36.60965300
    28Locked36.60965300
    29Locked36.38689000
    30Locked36.38689000
    31Locked36.60965300
    32Locked36.38689000
    33Locked396.588957130
  • Thanks for the reply, I'll remove the attenuator and check again
    Downstream power is too low, it should be above -6   Preferred range is -6 to +10    If you have an attenuator fitted, try removing it and check the power levels again.  Otherwise a VM tech will need to adjust those.
    13010000043.7705995120 KSym/sec64QAM4
    23660000043.7705995120 KSym/sec64QAM3
    34310000044.0205995120 KSym/sec64QAM2
    42360000043.7705995120 KSym/sec32QAM5
    54960000044.5205995120 KSym/sec64QAM1
    1US_TYPE_ATDMA0000
    2US_TYPE_ATDMA0000
    3US_TYPE_ATDMA0000
    4US_TYPE_ATDMA0000
    5US_TYPE_ATDMA0000
    610.448.12KQAM128
    6OFDMA20853.4210
