Speller's avatar
Speller
9 months ago
Losing connection now hub rebooting
A while ago started having problems with YouTube stopping and starting which gradually got worse.
Looked at hub logs to see lots of RS errors and warnings for RCS Partial Service and Lost MDD Timeout. The hub has now started rebooting itself and showing errors in the log
Cable Modem Status
ItemStatusComments
299000000
Locked
Ranged Upstream Channel (Hz)
43099996
Locked
Provisioning State
Online
12990000003.236256 qam21
21390000001.226256 qam0
31470000000.725256 qam0
4163000000-0.726256 qam4
5171000000-0.530256 qam5
6179000000-1.528256 qam6
7187000000-0.729256 qam7
8195000000-0.530256 qam8
9203000000-0.229256 qam9
102110000000.929256 qam10
112190000001.429256 qam11
12235000000135256 qam13
132430000002.235256 qam14
14251000000337256 qam15
152590000002.437256 qam16
162670000001.738256 qam17
172750000001.236256 qam18
18283000000336256 qam19
192910000003.537256 qam20
203070000002.533256 qam22
213150000002.234256 qam23
223230000003.737256 qam24
1Locked36.84710
2Locked2669350029273094
3Locked25.177929966736
4Locked26.71064650219318136
5Locked30.5685573577
6Locked28.723275088809236
7Locked29.9244896574756
8Locked30.623848991939
9Locked29.825471914464
10Locked29.52645048574
11Locked29.424649768225
12Locked35.5418360
13Locked35.2131990
14Locked37.36460
15Locked37.63070
16Locked38.94050
17Locked36.626560
18Locked36.66210
19Locked37.32760
20Locked33.9173253401701058
21Locked34.216917478805791
22Locked37.61730
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
14309999651512064 qam2
22359998651512064 qam5
33010001451512064 qam4
43659997151512064 qam3
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
A,.iyewrkldJKDHSUBsgvca69834n
SFID604
Max Traffic Rate575000085
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID603
Max Traffic Rate55000085
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Mod Edit : Personal information has been removed
Broadband quality monitor
https://www.thinkbroadband.com/broadband/monitoring/quality/share/570576fba285e8befb3df6b2d62cf8ec4d48b676
    There are far too many Pre RS Error and far worse Post RS Errors on the 3.0 Downstream channels.
    The 3.0 Upstream power level is on the high end, suggesting the Hub is working hard to satisfy the demand from the Street Cabinet.
    Check all the coax cables are secure at the wall & at the Hub and are free from damage or kinks.
    Check for known faults in your street – try both methods :
    Call the local fault line: 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
  • Can this post be deleted?  I didn't think it had posted, hub rebooted as I did it so I tried again and now see I have two posts for the same problem.
      Strange, I can only see the one post, but then again, this new Board software is a bit quirky ...
    A VM Hub reboot does not correct signal level issues and poor SNR figures.
    Are you quite sure this is fixed ?
    • Speller's avatar
      Speller
      It's not fixed.  I made this post and as I clicked publish I saw the log still mad MACs in, then the hub rebooted and when I got back here I couldn't see the post so thought it had not worked and made another separate one.  I see now the button says discussion so maybe I should have said delete this discussion.
        Irrespective, your shared BQM is a mess, so a VM technician will be needed to sort your connection out.   It will take a day or two for a VM Mod to pick this up and discuss with you.
