flaxthejute's avatar
flaxthejute
4 days ago
I need a new hub
After a recent thunderstorm, I realised that all but one of the ethernet sockets on my Hub 3 are not working. I've restarted the Hub several times and reset it to factory settings after a full power down and restart.
I've switched my desktop PC (which is ethernet connected) from socket to socket and I only get a network connection on one socket. WiFi seems ok.
I am tech savvy enough to fit a new Hub if I could get sent one.
Can one of the forum staff help?
  • Roger_Gooner's avatar
    Roger_Gooner
    If a thunderstorm caused damage to your hub you need a tech to come round and replace the isolator.
    The full factory reset process is:
    1) Press & hold RESET for 60 seconds.
    2) Leave the Hub powered on to complete the reset.
  • legacy1's avatar
    Are you sure the hub is not in modem mode?
    seems odds these thunderstorms cause so many problems with the hub maybe best to get a surge protector
    • flaxthejute's avatar
      flaxthejute
      The hub isn't in modem mode. The light on my surge protector that tells you it's working went out at the same time :(
      • legacy1's avatar
        guess you need a new hub you could maybe look at getting a UPS Sinewave
