Teebee's avatar
Teebee
Hub5 vs Hub3 WiFi
Whilst I wait for a fix for my Hub5 install a quick question to save me time testing.
My Hub3 signal was poor upstairs so I bought an Asus RT-AC86U, in the interest of less cables I was wondering if the Hub5 signal is better letting me retire the router.
Baz
  • I would not expect significant coverage differences between the various VM Hubs.
    Wi-Fi is a two way radio process, the signal from our mobile and laptop can be quite a bit lower than the Hub, often this is the source of the problem.  A problem that needs to be addressed by placing another Wireless Access point or Wireless Repeater in a suitable location.
    Looking past the WI-Fi issues, Hub 5 can be very flaky in Router mode but appears very solid as a Modem.
    Using the Hub 5 in Modem mode + the Asus RT-AC86U may be the best option for a stable & reliable system.
  • I had the same dilemma when I received my HUB5.  I decided to retire my TP-Link router and just use the HUB5.  So far so good, I've been running just the HUB5 for over a year now.  I think the signal is better, well that's my impression.
    • Teebee's avatar
      Teebee
      Thank you, I kind of expected that response just trying to avoid unnecessary testing.
  • Teebee's avatar
    Teebee
    A quick update, as I destroyed my network during the fix phase I did do some testing with both SSID's active, the Hub5 came back with a better Db rating on both 2.4Ghz and 5Ghz so for now I am running without the Asus.
    • Robert_P's avatar
      Robert_P
      Thanks for the update TeeBee, please keep us up to date with this if there are any further developments or just give us a shout if you need assistance in the future.
      Rob
