wannnnnabe's avatar
wannnnnabe
Hub3 solid red light and drop connection
Hi all,
I got solid red light on Hub3 for a month and the upper part of router a bit warm (not very hot).  I'm using M350. The connection of connected device will drop suddenly.  I have try to reset and restart the router.  Also, I have taken out all the cables and plugged them in again. Unfortunately, solid red light still come up.
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
    • wannnnnabe's avatar
      wannnnnabe
      Thanks Adduxi.  Yes, I got the private message from VM team.
      • Daniel_Et's avatar
        Daniel_Et
        Hi wannnnnabe,
        We're glad this has been resolved for you.
        If you have any further queries, please don't hesitate to contact us.
        Regards,
        Daniel
    Daniel_Et
    Hi wannnnnabe 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the problem you're having 😔
    In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
    Thank you for your support Adduxi 👍
    Regards,
    Daniel
