bp3's avatar
bp3
Hub 6 - Wifi Pods Compatibility
We have recently upgraded to the Virgin Media Hub 6 and had a few Wifi pods throughout the house Model No. PP01-VM.
Are these compatible with Hub 6 or are different ones now needed?
    • bp3's avatar
      bp3
      Sorry got confused I have a hub 5 not 6 and in the UK
    If you have VM Pods that worked with the previous Hub but are now offline...
    Call the activation number 0800 953 9500, request the VM Pods are re-paired to the replacement Hub.
    For the call have to hand your VM a/c number, the full details from the Hub’s sticker and ALL the VM Pods.
