Connect your own router to one of the 1Gb port (1-3) whilst having the fibre and power also connected but no other ethernet or wireless clients
via your own router LAN side access the VM Hub (the reason for this is the hub only sees the WAN MAC address of your router and no others)
now factory reset the Hub
once the Hub has rebooted browse to http://192.168.0.1 and configure the password for it, once you are on the standard status page access http://192.168.0.1/?page=modemmode and enable it.
the Hub should reboot and assign your device an IP if it does not try and power cycle your device. it can take several minutes to assign so be patient.
