BellB666's avatar
BellB666
2 months ago
Hub 5 Solid White Light but No WiFi/Ethernet Connection
Last night, I had noticed that the light on my power adaptor for my Hub 5 had gone out. I figured that it probably had popped while I was out and decided to replace the plug with a similar adapter wi...
  • Sephiroth's avatar
    2 months ago
    Whatever popped your adapter is likely also to have popped the Hub.  Power surges can do that.  You now have the Christmas problem and I suspect nothing can be done about it.  The only thing you might care to do is nip out to Curry's or somewhere, buy a cheap wireless router and tether your phone to the router's WiFi.  Then, at least, you'll be able to have something working over Christmas.
