Nicki_81's avatar
Nicki_81
Hub 5 flashing red
     My broadband has been intermittent for awhile now, losing signal on wired and wireless devices.
I do the checks on the virgin media website, which most of the time leads me to resetting my hub 5, which works for awhile. Now the hub is randomly flashing red, never had this issues before. I've read that it could be overheating, but the hub has plenty of airflow around it and only feels warm to the touch.
Any help would be much appreciated.
  • jbrennand's avatar
    Check first for any “known network faults in your location - Look in 2 places and report back here exactly what they state.  Red light and overheating is a Hub3 issue - not Hub5 AFAIK.
    1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
    2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
  • Akua_A's avatar
    Akua_A
    Hi Nicki_81
    Welcome back to our community forums and sorry to hear you are having issues with intermittent broadband and a red hub light. We can understand your concern. We can however see that our team recently sent out equipment to resolved this. Can you confirm if the issue is ongoing? Do you need any further help?
    • Nicki_81's avatar
      Nicki_81
      I was told that it was a power supply issue that is causing this red light, i am still waiting for replacement power supply. It is still ongoing, just had it happen twice in less than 10 minutes. As you can imagine, it is really frustrating while trying to watch netflix or other streaming apps.
      • Zach_R's avatar
        Zach_R
        Hi Nicki_81,
        If the router was having issues receiving power from the power supply then there'd be no light at all, as without power it can't create the light.
        Please respond to the private message that I'll be sending to you shortly and we can proceed from there.
  • Hello,
    Im having this issue now, I believe its either the box or the connection outside, Got someone coming monday to look at it but that would mean I have the whole weekend with no internet which is horrid.
      Use a mobile hotspot if the task is so critical.
      What Hub are you using?  Have you checked the status on the Hub's console as to whether it's online or offline?
      Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
