chs117's avatar
chs117
4 hours ago
Hub 5, channel opitimisation
Hub 5, trying to get 2.4 connection . When I untick Enable Channel Optimisation, I get message "108 is RFS Channel". What should i do
    That message refers to the 5Ghz channel.  108 is a DFS channel and as such will have a short delay in transmitting, as by law, the Hub has to check for Radar stations in the area.  It's nothing to worry about.  You can move the channel to, e.g. 36 as it's not a DFS channel.
    See this link for a guide - Understanding DFS Channels | Wyebot Docs
  • legacy1's avatar
    reset the hub use its defaults
    or get your own router with 1Gb or 2.5Gb ports and use hub in modem mode
