DenzilDexter's avatar
DenzilDexter
4 months ago
Hub 5.0 Connection Loss
Hello Community,
I've just updated from a hub 3.0 to a hub 5.0 and now I'm saying frequent broadband interruptions. Here are the down stream channels - are these normal?
Router status
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
194000000
1
39
QAM 256
8
2
138000000
3.5
39
QAM 256
1
3
146000000
2.7
38
QAM 256
2
4
154000000
2.2
38
QAM 256
3
5
162000000
1.7
38
QAM 256
4
6
170000000
1.3
38
QAM 256
5
7
178000000
1.2
38
QAM 256
6
8
186000000
1
39
QAM 256
7
9
202000000
0.8
39
QAM 256
9
10
210000000
0.6
39
QAM 256
10
11
218000000
0.6
39
QAM 256
11
12
226000000
0.3
39
QAM 256
12
13
234000000
0.4
39
QAM 256
13
14
242000000
0.9
39
QAM 256
14
15
250000000
0.8
39
QAM 256
15
16
258000000
0.9
39
QAM 256
16
17
266000000
-1
39
QAM 256
17
18
346000000
-3.3
38
QAM 256
27
19
354000000
-3.5
38
QAM 256
28
20
362000000
-3.9
37
QAM 256
29
21
370000000
-4.4
37
QAM 256
30
22
378000000
-4.7
37
QAM 256
31
23
386000000
-5.1
36
QAM 256
32
24
394000000
-5.7
38
QAM 256
33
25
402000000
-6
38
QAM 256
34
26
410000000
-6
38
QAM 256
35
27
418000000
-6.6
37
QAM 256
36
28
522000000
-10.9
34
QAM 256
37
29
530000000
-10.9
35
QAM 256
38
30
538000000
-10.8
34
QAM 256
39
31
546000000
-10.8
34
QAM 256
40
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
39
24
0
2
Locked
39
515
20
3
Locked
38
493
18
4
Locked
38
683
76
5
Locked
38
376
19
6
Locked
38
38
0
7
Locked
38
16
0
8
Locked
39
17
0
9
Locked
39
84
0
10
Locked
39
284
0
11
Locked
39
350
11
12
Locked
39
45
0
13
Locked
39
35
0
14
Locked
39
42
0
15
Locked
39
37
0
16
Locked
39
279
17
17
Locked
39
112
0
18
Locked
38
223
0
19
Locked
38
251
0
20
Locked
37
416
0
21
Locked
37
703
0
22
Locked
37
771
0
23
Locked
36
861
0
24
Locked
38
1382
0
25
Locked
38
1554
0
26
Locked
38
1534
0
27
Locked
37
2236
0
28
Locked
34
36026
0
29
Locked
35
36910
0
30
Locked
34
36488
0
31
Locked
34
38684
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
41
190
4K
3736
QAM 4096
148
Channel ID
Locked Status
RxMER Data (dB)
PLC Power (dBmV)
Corrected errors (Active Profile)
Uncorrectable errors (Active Profile)
41
Locked
0
-21.9
28067657
971484094
DD
    The Downstream Power level has a preferred range of -7 to +7 dBmV however...
    3.0 Downstream channels 28 to 31 are well below this at -10.8 & -10.9 dBmV
    3.1 Downstream is considerably lower at -21.9 dBmV
    I suspect a local street cabinet issue is the problem, if not your are going to need an engineer to fix.
    Check for known faults in your street. Try both methods:
    Call the local fault line: 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
  • jpeg1's avatar
    jpeg1
    The highest frequency channels are losing the most signal, which usually suggests a cable fault somewhere between the street cabinet and your Hub. The first thing to check is that the coax connections inside the house are tight and the cables are not damaged. If those are all secure then you will need to phone CS and report the fault.
  • Alessandro, thank you for your advice.  My original Hub 3.0 required an attenuator to be fitted inline at the Hub as the SNR was too high all those years ago. I've left this in place - could this be the issue?
      Just remove the attenuator and check the levels are in spec.
  • That is of course the obvious thing to do.  Is there a page specifying the levels (or is it simply a range of -7 to +7 dBmV for power levels).
      No, no page, but I usually use -6 to +10 for DS and 34 to 51 for US.  All QAM64 and PostRS errors to be zero or close to.
    • jpeg1's avatar
      jpeg1
      If there is a significant difference in levels across the frequency range, this is very likely due to the coaxial cable not having a constant impedance from end to end. This could be due either to a faulty termination, or damage somewhere along its length.
      This causes what is known as a standing wave within the cable. This wave has a different length according to the frequency 'wavelength' of the signal, and will cause channels of different frequencies to appear at different levels at the Hub.
  • I removed the attenuator at the Hub 5,0 input.  I now get this which looks better but I'm still not sure it's right. All QAM64 and PostRS errors are not that close to zero in some cases.
    Channel    Frequency (Hz)    Power (dBmV)    SNR (dB)    Modulation    Channel ID
    1    194000000    7.9    39    QAM 256    8
    2    138000000    10    39    QAM 256    1
    3    146000000    9.5    38    QAM 256    2
    4    154000000    9    38    QAM 256    3
    5    162000000    8.7    38    QAM 256    4
    6    170000000    8.4    39    QAM 256    5
    7    178000000    8    39    QAM 256    6
    8    186000000    7.9    39    QAM 256    7
    9    202000000    7.4    40    QAM 256    9
    10    210000000    7.2    40    QAM 256    10
    11    218000000    7.2    39    QAM 256    11
    12    226000000    6.7    39    QAM 256    12
    13    234000000    5.9    40    QAM 256    13
    14    314000000    3.5    40    QAM 256    23
    15    322000000    3.4    39    QAM 256    24
    16    330000000    3.2    39    QAM 256    25
    17    338000000    2.7    39    QAM 256    26
    18    346000000    2.9    39    QAM 256    27
    19    354000000    2.8    39    QAM 256    28
    20    362000000    2.2    38    QAM 256    29
    21    370000000    1.8    38    QAM 256    30
    22    378000000    1.6    38    QAM 256    31
    23    386000000    1    37    QAM 256    32
    24    394000000    0.5    39    QAM 256    33
    25    402000000    0.4    39    QAM 256    34
    26    410000000    0.2    39    QAM 256    35
    27    418000000    0.4    39    QAM 256    36
    28    522000000    -4.8    36    QAM 256    37
    29    530000000    -4.7    36    QAM 256    38
    30    538000000    -4.6    37    QAM 256    39
    31    546000000    -4.7    37    QAM 256    40
    Channel    Locked Status    RxMER (dB)    Pre RS Errors    Post RS Errors
    1    Locked    39    0    0
    2    Locked    39    12    0
    3    Locked    38    15    0
    4    Locked    38    17    1
    5    Locked    38    3    0
    6    Locked    39    0    0
    7    Locked    39    0    0
    8    Locked    39    0    0
    9    Locked    40    0    0
    10    Locked    40    0    0
    11    Locked    39    2    0
    12    Locked    39    0    0
    13    Locked    40    5    0
    14    Locked    40    1    0
    15    Locked    39    2    0
    16    Locked    39    2    0
    17    Locked    39    1    0
    18    Locked    39    28    0
    19    Locked    39    3    0
    20    Locked    38    5    0
    21    Locked    38    7    0
    22    Locked    38    7    0
    23    Locked    37    6    0
    24    Locked    39    15    0
    25    Locked    39    12    0
    26    Locked    39    17    0
    27    Locked    39    16    0
    28    Locked    36    176    0
    29    Locked    36    169    0
    30    Locked    37    179    0
    31    Locked    37    205    0
    Channel    Channel Width (MHz)    FFT Type    Number of Active Subcarriers    Modulation (Active Profile)    First Active Subcarrier (Hz)
    41    190    4K    3736    QAM 4096    148
    Channel ID    Locked Status    RxMER Data (dB)    PLC Power (dBmV)    Corrected errors (Active Profile)    Uncorrectable errors (Active Profile)
    41    Locked    0    -14.6    432834    5640055
    Thoughts?
    DD
  • And the errors seem to be increasing:
    5    162000000    8.6    39    QAM 256    4
    7    178000000    7.9    39    QAM 256    6
    10    210000000    7.1    40    QAM 256    10
    12    226000000    6.6    39    QAM 256    12
    18    346000000    2.8    39    QAM 256    27
    19    354000000    2.7    39    QAM 256    28
    20    362000000    2.1    38    QAM 256    29
    21    370000000    1.7    38    QAM 256    30
    22    378000000    1.5    37    QAM 256    31
    23    386000000    0.9    37    QAM 256    32
    25    402000000    0.3    39    QAM 256    34
    26    410000000    0.1    39    QAM 256    35
    27    418000000    0.5    39    QAM 256    36
    29    530000000    -4.8    36    QAM 256    38
    30    538000000    -4.7    37    QAM 256    39
    1    Locked    39    2399    1072
    2    Locked    39    2202    2172
    3    Locked    38    120    30
    4    Locked    38    3114    2471
    5    Locked    39    2622    2094
    6    Locked    39    2459    1468
    7    Locked    39    852    868
    8    Locked    39    11    14
    9    Locked    40    2414    1407
    10    Locked    40    2270    1608
    11    Locked    39    8063    2016
    12    Locked    39    31738    3500
    13    Locked    40    2177    1882
    14    Locked    40    336    153
    15    Locked    39    2118    1349
    16    Locked    39    1845    907
    17    Locked    39    2497    1435
    18    Locked    39    2379    1477
    19    Locked    39    27    23
    20    Locked    38    28    0
    21    Locked    38    131    1
    22    Locked    37    66    0
    23    Locked    37    47    0
    24    Locked    39    92    0
    25    Locked    39    3021    1950
    26    Locked    39    126    4
    27    Locked    39    3260    1142
    28    Locked    36    436    0
    29    Locked    36    3608    642
    30    Locked    37    3402    570
    31    Locked    37    4552    1142
    41    Locked    0    -14.9    1978520    18636098
  • legacy1's avatar
    Seems you have a faulty amp you are connected too.
    • DenzilDexter's avatar
      DenzilDexter
      Alessandro, what does that mean?
      • legacy1's avatar
        Outside something broken it would explain why your downstream is so low and likely just about worked for hub 3 but with more channels and Docsis 3.1 channel on hub 5 is now not good enough for a stable connection that and power levels are all over the place.
  • It took almost 4 weeks but we had a VM Engineer here on the 31st. It seems the fault with the levels and errors are also at the local cabinet, I think he said on multiple taps. That means he didn't fix it and I have to wait for the network team to take a look.
    • Martin_N's avatar
      Martin_N
      Thank you for that information DenzilDexter. Did the engineer advise a timeframe for that?
      ^Martin
