TopDoc03's avatar
TopDoc03
Hub 4 not found in Connect App
I can see that many people have reported a similar problem but despite every single troubleshooting step including the good old 60sec reset, my VM Connect app still cannot find the hub. In terms of providing the Internet connection and Wi-Fi, that is working however the hub and Connect app don’t seem to be able to talk to each other.
I’m hoping a member of staff can reach out to me from this forum post and find a resolution.  I have already called a few days ago and had a discussion on the phone but no resolution achieved.
    Perhaps, given Hub 4 modem mode customers are not reporting Hub 4 admin menu failure.
    With Hub 4 when the Connect app looses connection, the Hub 4 admin menu has often also failed.
    • jbrennand's avatar
      Another reason for using modem mode then  😎
    What tasks do you want to use the connect app for that you cannot do by simply logging into the hub's settings?
    • TopDoc03's avatar
      TopDoc03
      Unfortunately I can’t even log into the Hub’s settings. I get a blank white screen every time
      • Martin_N's avatar
        Martin_N
        Hi TopDoc03,
        Thank you for your post and welcome to the community.
        I'm very sorry to hear about the issue you're having with the connect app.
        Are you trying to sign in on a Wired device or Wireless?
        ^Martin
