virkon
8 months agoOn our wavelength
Hub 4 hot
Hi all, I've had a hub 4 for 3 days can I ask, is it meant to be this hot? My hub 3 was nothing like this. I can't hear a fan. Thanks for any input, Regards, John
Clogged with dust after 3days?
VM recycle Hubs as they are all rented by users. It is quite possible there is an accumulation of dust from a previous user. Obviously if it is a brand new unit, then yes, there would be no dust, and could be a faulty fan. As noted before, this is the only Hub with a fan and as such it can get dusty. All the other Hubs are fanless, so do not exhibit this problem.
