virkon
8 months agoOn our wavelength
Hub 4 hot
Hi all, I've had a hub 4 for 3 days can I ask, is it meant to be this hot? My hub 3 was nothing like this. I can't hear a fan. Thanks for any input, Regards, John
See here
Your link brings up 'invalid perimeter'
"Invalid parameters" I should have said
Thanks for reaching out to us virkon, and welcome back to our Community Forums!
Sorry to hear of the hot Hub 4 you have been using.
Can you please confirm if you have attempted to switch the hub off and dusted it down?
Do you have a solid red light appearing on the hub at all?
David_Bn
Hi no and no. I discovered the network diagnosis in the settings and it says it is normal temperature even though I think it's way too hot.
Also I read somewhere that some users were complaining that the fan is very noisy, but I'm not getting that mine is totally silent.
