Tuftusmaximus's avatar
Tuftusmaximus
Just browsing
10 months ago
Hub 3 Replacement
I have the dreaded continous red light on my Hub 3 and was told a replacement was ordered on Sunday. I received a text to say it would be delivered yesterday (Tuesday), but I haven't received it, nor had any correspondence from Yodel. There is nothing in my 'open orders'. Please can someone help? Thanks!
  • Hi Tuftusmaximus
    Sorry to hear you've not received your Router.
  • Hi Tuftusmaximus
    • Tuftusmaximus's avatar
      Tuftusmaximus
      Just browsing
      All sorted! Thank you for getting this resolved for me. Much appreciated.
    Yes, you are correct, if the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly.
    Hopefully a VM Mod should pick this up within a day or two and find out where your replacement Hub is.
