praeter's avatar
praeter
Hub 3 - Red Light - can't resolve by Contacting Virgin
Tried to call Virgin this morning but no options to actually speak to anyone with this query. Also the Web Chat is not working, so pretty disappointing to start with!
The issue I have is a Hub 3 with a solid red light. It's not a heat problem as the hub is warm but not over-heating. Also tried turning it off for a while to cool down and still had the red light showing. I assume that it's a different fault with the Hub. Broadband and Wifi is working OK but I think I need a new Hub. How do I resolve this issue?
  • Swapped for a new one - all working fine now - thank you!
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
    It can be the LED is fading or it can an over temperature fault.
    To check login in to the Hub 3 menu at http://192.168.0.1/   use the numeric HUB PASSWORD from the bottom side label.   ( this is not the Wi-Fi password )
    Run the Network diagnostic tool
    Scroll down through the results and find the Temperature entry.   Is it normal ?
  • Thank you both - neither works unfortunately. Still the same after reset and the Network Diagnostic tool just fails each time!
  • Alex_RM's avatar
    Alex_RM
    Hi praeter,
    Thanks for posting and sorry to see there's an issue with the hub.
    This will need a technician visit, so I've popped you over a private message to get a few more details from you.
    Alex_Rm
  • Alex_RM's avatar
    Alex_RM
    Thanks for joining me over private message praeter 🙂
    Glad I was able to help, please pop back and let us know how the technician visit goes.
    Alex_Rm
    • praeter's avatar
      praeter
    Using Firefox, the Hub 3 Network Diagnostic tool always fails for me.
    Using Edge or Chrome, the Hub 3 Network Diagnostic tool works perfectly every time.
