MickL1's avatar
MickL1
5 months ago
How many WiFi pods
I have a hub5 and 3 white pods and 1 black pods. The WiFi pods all connect ok and function most of the time but randomly lose connection about once or twice a day .
can I use 4 pods with the hub 5
how do I find out if all the pods are linked to my router on my account by Virgin
  • Roger_Gooner's avatar
    Roger_Gooner
    The black pods are better than the white ones, and it's best to connect them by Ethernet cable to the hub as wired backhaul gives best results by far.
  • legacy1's avatar
    If you need that many pods there is something wrong with your hub Wifi
    I thought the maximum number of Pods was 3?  Besides with a Hub 5 you should be looking to send the 3 white pods back, and get an additional 2 black pods.  I suspect part of the problem is the number of pods, as there are really only 3 viable 2.4Ghz bands available, 1 , 6 & 11.
    • MickL1's avatar
      MickL1
      I have turned off one pod now , so now have 2 white pods and one black one , the system has been stable since I did this but it is early days yet . Thanks for advice
      • MickL1's avatar
        MickL1
        The internet is still unstable at times so I have now ordered back pods to replace the white ones . The system will be three black pods and hub 5 , see how that goes.
        I know 3 pods sounds a lot but my bungalow is very long and L shaped .
    Folks usually use the VM Connect app to see the VM Pods in their home network.
