derekpears's avatar
derekpears
Settling in
17 days ago
Dead WiFi Pod?
I’m not sure when this happened exactly but I’ve noticed I’m not getting any signal anymore from my WiFi pod (which I’m sure used to work!). VM Connect confirms it’s no longer on the network, which remains the case post reset of the hub.
I have moved to closer but it does nothing on plugging it in, no lights flash, just…zero effect. It doesn’t appear to have a reset button like the old ones do (I have the newer hexagon shape).
Is there anything I can do or try? I’m sure the app used to have any option for getting a new one sent but that doesn’t seem to be the case now.
  • Hey dekerkpears, thank you for reaching out and a warm welcome to the community, we are sorry to hear about your WIFI pod being dead.
    Let me send you a DM now :)
    Looks like you have done all you can, and the Pod is indeed broken.
    As this is a Community Forum, and not a direct line to VM as such, it will take a day or two for a VM Mod to pick this up.  If you need is urgent, it would be best to phone Customer Services directly.
