collingsa
19 days agoJust joined
Broadband help
I have been with Virgin approx 2 weeks, external works done with no problems
Since being connected I have had problems with smart phones disconnecting after a few seconds of Internet access, having to manually reconnect. Smart WiFi etc all turned off on phones.
I've had a really helpful engineer come out today and replace the box and talked me through everything and it all seemed to be fixed, but half an hour later I'm facing the same problems again
My TV & streaming is fine
Engineer said to do a reboot which I've done but doesn't seem to have fixed the problem
Quite frustrated with it now, was hoping for good things from Virgin.
