bathandy's avatar
bathandy
Very slow uplink speed
First time poster
My M350 broadband is fine for download but really slow for upload 4 to 9 Mbs
I have run the network checks on the router and on the VM main site and they say its all good
The network log on the router shows occasion synchronization lost but everything else looks fine , the status currently shows no problems
I expect a higher upload speed but its low on broadband speedchecker and on VM broadband speed check
Is this upload speed normal ?
  • Hi Allessandro
    It was fine until I rebooted it a few days ago . If I use my secondary IP Provider (3) also connected by cable , then upload and download are fine .This all direct attached Ethernet.
    For completeness I will attach a alptop direct to the Hub and retest , but am not optimistic, will post back in a bit
  • legacy1's avatar
    run a cmd
    ping -t 194.168.4.100
    on upload see if ping spikes
  • ran it for over 280 pings ,all looks good now
    Reply from 194.168.4.100: bytes=32 time=13ms TTL=59
    Reply from 194.168.4.100: bytes=32 time=14ms TTL=59
    Reply from 194.168.4.100: bytes=32 time=38ms TTL=59
    Reply from 194.168.4.100: bytes=32 time=11ms TTL=59
    Reply from 194.168.4.100: bytes=32 time=16ms TTL=59
    Ping statistics for 194.168.4.100:
    Packets: Sent = 283, Received = 283, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
    Minimum = 9ms, Maximum = 41ms, Average = 14ms
  • I will keep an eye on the connection over the next few days, but at the moment its all working as expected
