peteclen's avatar
peteclen
10 months ago
1Gb Volt package
Only getting speed of 82Mb in same room as router. 50Mb or less in other rooms.
VM Connect app hopeless. Keeps failing, saying I appear to be out!!
  • Vikki_M's avatar
    Vikki_M
    Hi peteclen,
    Thanks for your post and welcome back to our community.
    I'm sorry to hear you're having some issues with the WiFi.
    Are you having issues ordering a WiFi pod via the connect app?
    I'll send you a private message now so I can check the speed to the hub and help order a Pod if that's what you'd like to do.
    Please look out for the envelope in the top right of the page and pop back to me when you can.
  • jpeg1's avatar
    jpeg1
    VM only guarantee 30Mbps download speeds by WiFi.
