spiderrob's avatar
spiderrob
11 months ago
Move cable entry point
I need to move my cable/broadband entry point. I go round in circles on the telephone line - any ideas how to get this sorted?? Thanks
    Hi spiderrob
    There would be a £25 non fault call out charge (it used to be £99) to do the work you require.
    You should call  150 from a Virgin landline, or 0345 454 1111 from any other phone, option 2 (Faults)
    Or wait a day or two and a member of the Forum Team should pick this up for you and arrange a tech visit.
    Like
  • Carley_S's avatar
    Carley_S
    Hi spiderrob
    Sorry to hear that the team haven't been able to support you on this request.
    Just to confirm. are you looking to relocate any external cabling from the cabinet to the property, or are you looking to relocate/rewire equipment internally?
    • spiderrob's avatar
      spiderrob
      Hi, I’m just looking to move internally in the same room. The cabling comes to the outer wall and then runs along externally 5m and through into the room. I want the entry into the room moved onto another wall. Technically the external cabling just needs shortening by 5m and the internal box and connection moved to another wall.
      • Daniel_Et's avatar
        Daniel_Et
        Hi spiderrob, thank you for your response.
        In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
        Regards,
        Daniel
