MrHalfAsleep's avatar
MrHalfAsleep
Community elder
10 months ago
Problems with forum
I have had problems accessing the forum over the last two days; I find myself now able to access posts.  My ID stated that I "didn't exist", nor could I access anything on the forum.  I went surfing the forum in circles,   Under the settings section there are 12 different IP addresses (some internal beginning with 10, others with 81, 82 and one 193).
This leads me to think (ask) of the following:
  • has the forum been hacked?
  • is there a data breach?
  • have I done something wrong or posted stuff that is objectionable?
  • (as mentioned elsewhere) a bug with CloudFlare (as I get the occasional 502 bad gateway error)?
  • is it bugs or errors in the forum software?
  • is it a Windows problem?
  • am I being stupid?
  • all/none of the above.
If it were bugs or errors in the software, I presume they have now been fixed as I can now make posts again.  Any comments, help etc are welcome.  Cheers.
  • legacy1's avatar
    Well this 10. thing could be an experiment for Ipv6 mapped to some 10. to server so that servers don't need to be IPv6?
  • goslow's avatar
    goslow
    Have not experienced these particular issues for a while but I now seem to have come full circle back again to experiencing
    Access denied (on the browser tab)
    This message cannot be found
    Let's get you back on track
    Go to community home
    and edits to topics failing to appear without additional updates and page refreshes.
    I am struggling to think of any piece of software or website I have ever used previously which has been quite so glitchy and bug-ridden as this forum is.
    • Cardiffman282's avatar
      Cardiffman282
      Community elder
      Yup same here. It's tempting to blame VM but it's probably Khoros. I wonder if any other community forums are on the same version and seeing similar.
  • goslow's avatar
    goslow
    And today I am back to being blocked from logging in with the familiar
    Unexpected Error
    Please try refreshing the page and submitting again.
    4 or 5 tries later login is allowed.
  • I know I'm a bit slow but I think I have worked out how to get around the blank Inbox issue. Users need to click on the cog once in the Inbox and select "show unread only".
      That doesn't work for me, instead I have to type "re"  (without the quotes) and it can take a few attempts.
        Cardiffman282
        Community elder
        It works for me for new unread messages. All read stuff stays hidden as you say unless you use search terms like re, hello, etc
    • Graham_A's avatar
      Graham_A
      I'm puzzled by these last few messages: what blank inbox issues are people seeing?  Are you referring to the private message facility?  That is the only 'inbox' I can think of within this community forum.
